Unimat tool holder
  • Unimat tool holder
    Anyone have a good plan for a QCTP for a Unimat? I saw one on the bay that looked pretty nice. Bob.
    I've seen them clamped to the table of a mill, but never seen one clamped in a toolpost.
    Dan
    (sorry. Won't it use the same QCTP as a 7x10 lathe?)
      I started to scale my design for the Unimat but never finished the project. The biggest problem was the limited clearance above the cross slide. I also wanted to add a compound slide and that did not help the situation.
      As for using one designed for the 7X10, I highly doubt it as the Unimat is about a 3X6 and would require a significantly smaller design.
      Make it fit.
        Here's one from the Files section of the Yahoo group - UNIMAT
        http://finance.groups.yahoo.com/grou...les/SL%20QCTP/
        If the link doesn't open, then you go join that group and swipe it.
        Ohh, it works brilliantly, I've been using this design for over a decade with no problems.
