What did you machine today?
  • I'd be interested in seeing pictures of that CNC lathe, looks very nice.
    • Thanks! Here's some pictures and videos. There are some differences as what I have now is the 3rd prototype and some pictures and video are of the 2nd prototype and 3rd prototypes.
      • briuz, that's very impressive.
        • Thanks!
          • Finished my Cessna 180 wing adjustment nuts for a friend. These were the parts that grew made from 2024. His 180 is an experimental home built copy of a C180 called the Cyclone. I think he is the only person to ever finish one of their kits.
            • RB, are these for tightening the wing spars to the fuselage? Jim
              • Originally posted by jmm03 View Post
                Don't know friend sent the drawings, he made the old ones, wanted new ones. Think they are for adjusting the wing incidence. 2 per wing.
                • 80% material removal, 30 of these would have been a very long and boring job with a manual lathe.
                  2 1/4" round 6061 4 1/2" long with a .197" hole thru, the small end dia. is .472" +.0000 -.0008 and the undercut is .394".
                  The large end is 2.205"
                  • Bented I think you've left that slightly longer than is traditional for a toilet roll holder
                    • When I first saw the customers drawings a very expensive door stop came to mind.
                      No idea what they do in use.
                      The next op is to face the flange to .079" (2 mm) then hard anodize.
                      • I machined some vintage switch plates to work with GFI receptacles and round telephone jacks. The mounting screw holes for the 1-Gang duplex receptacle had to be drilled in the new location to work with the GFI. I had to drill and tap the steel ring 6-32 behind the telephone cover for it to work. There are probably at least 20 more of these to do.
Name:	Switch plate.jpg
ID:	1923680 Click image for larger version
Name:	GFI cover.jpg
ID:	1923681 Click image for larger version
Name:	telephone cover.jpg
                        • Briuz, this is amazing! Excellent workmanship and design. Not to mention the resultant work it does.
                          I'd love to have one of these.
                          Salem, Oregon
