Finished this small production run today. 30 parts of each size (8, 9, 10mm OD). 17 engraved with size, 13 blank. 1" long 1.5mm thru hole and a 1mm wall thickness on the big end (0.5mm small end). I designed/machined them for a customer that needed a problem solved with a new product.
CNC outer profile, spot, drill 1.5mm, part off. 2nd op in a hardinge hlv-h to drill the backside. Engrave size in the Mill in a quick fixture 2 at a time, then back between centers on my myford at home for a quick final green scotch bright brushed finish.
Had some trouble drilling the 1.5mm hole about 20 parts in, and then again after about 5 more parts (coolant/chip packing issues). Only had one drill left, so decided to just drill them by hand for the rest. Added some cycle time, but I made the rest with one drill no prob (picture is last part drilled). Drilling by hand took a bit of gravy off the biscuit, but they got done, and I still ate so it's all good. This will hopefully turn into a decent product for the customer, and will lead to more sizes and bigger orders in the future.
I wish I had more time to figure out the nakamura programming, and write a good post processor, as this would have been a gravy job for the live tools (engraving) and twin spindle to drop them complete. If she ends up ordering more I'll put more effort into figuring it out. Bit of a fun job. I don't get to do these very often anymore.
