Interesting mechanism at N.A.M.E.S.
  • Interesting mechanism at N.A.M.E.S.
    I saw a mechanism I'd never seen before at the N.A.M.E.S. show, but neglected to inquire about it. It's now stuck in my mind and I'm wondering what it's called.
    I saw it on several different models so apparently it was quite common in antiquity.
    It's a right angle drive, with four 90-degree "tubes" between the driving shaft and driven shaft. The tubes are free to slide in and out of one hub, and free to "spin" on the other hub.
    The net effect, besides rotary motion, is like an optical illusion as it turns.
    I'd like to learn more about it.
    Can anyone identify this for me
    Sounds like a governor to me.
      Found a modern example on Youtube:
      http://www.youtube.com/watch?v=fz1rmuaZZOM
        Google "elbow engine".
          There is a 90 degree drive I can think of where rods or tubes bent at 90 degrees can slide in and out and turn in 2 hubs with close fitting holes. I was not able to come up with the name of it. You guys are fast! Beat me to it.
            Another video:
            http://www.youtube.com/watch?v=3eFmMi4eHCI
              Early on, miter gears were difficult to make. Some genius came up with this elbow design that provided right-angle drive without gearing.
                Machining miter gears is easier than making a working elbow engine, in my view.
                  Oops - wrong mechanism. This is the one I was thinking about: https://www.youtube.com/watch?v=S_lG1Irw9BE and https://www.youtube.com/watch?v=S_lG1Irw9BE
                  My old mentor, Dan Fay, told me about its being an easier-to-construct substitute for miter gears. I wouldn't be surprised though if the elbow design was a similar attempt.
                    I made a steam engine in high school.. Pretty cool - Never did make the fly wheel for it.. The plans for it where found in an old popular mechanics iirc.
                    https://www.youtube.com/watch?v=A4u-Aj5Iwo0
                    sam
                      Boy I wish people that take pictures and post them would TRY to use enough
                      light to make the things visible on my monitor. :-(
                      Those two are so dark it's just a black hole.
                      ...lew...
                        Sorry -- I duplicated the link. The 2nd link was supposed to be a different video that was more clear. Try this: http://www.youtube.com/watch?v=PsUF1wP22iM
                        (I agree with you about the darkness of the first video. FWIW, having been to the Yankee Steam-Up and seen that exact mechanism in operation, it's so black with grease and oil it's difficult to pick out the detail standing right next to it.)
                          You're nobody in the model engine-making community until you've made your own elbow engine.
                          The hand-bent double-ended pistons have to have an exact ninety degree bend or the whole thing will bind up.
                          Regards, Marv
                            Forgot I have some other pictures..
                            While the other high school kid where making a hammer in shop class... It has been kicking around for a good 20 years.
