dumb little project CONTINUED
  • dumb little project CONTINUED
    Then I put the steel rod through the thumb hole, slid the magnet-holding disc up inside the tube, and welded the blank over the open end:
    Then I welded a little piece of tube crossways over the rod end for a handle:
    Now I have a solidly-made magnetic pickup that works very well and should last just about forever. I know that I can buy the functional equivalent in plastic and stink from Harbor Freight for under a sawbuck, but dang it, I like mine better!
    metalmagpie
    Good thinking magpie, for future reference, you don't have to start a new thread, just reply to your own post with 4 more pictures. Repeat until you are done.
    James
      You can also just join the pictures together vertically and they will be seen as "one".
        What exactly do you do with your "thing"? It looks to me that the magnet sits on the bottom. Do you pick up steel bits and pieces at the welded on end and to release pull the handle up?
          Hm- I've not had a problem knowing what to do with my thing
          Somebody would have said it-
          Great idea magpie- I need a magnetic pickup device like that.
            I use a welding ground magnet on my 4 legged cane & it's amazing what I find. Handmade nails, etc. Works well.
            country, in easy stages."
            ~ James Madison
              You can't believe how strong those 5.25 inch hard drive magnets are (from some "obsolete" 50G IBM server drive arrays). The type I gave MM are so strong they are almost imposssible to separate by hand. And they are realy good at slamming together and cutting the ends of fingers
                No no no... it's for digging up magnetic clams! Being downstream of Hanford, they abound on the WA coast
                  James
                  Well, duh. But why the 4-img rule anyway? Is someone spamming the board with lots of pictures? - MM
