Thursday's Job....Blind hole end bell
  • Thursday's Job....Blind hole end bell
    Hi
    The question gets posted here from time to time "what did you do today?"
    Well here goes:
    This job was a pump housing that had a bad bearing surface on the inside of the pump.
    Only one end came off the pump so I had to 'work around it'
    I set in up in the 'Lion lathe' and bored a hole to make a start.
    After taking careful measurements I bored out the old bearing surface.
    I then MFG a new bearing surface sleeve in the Colchester Lathe.
    (two lathes comes in handy!)
    Drove the new sleeve in the housing (small shoulder to keep it from going too deep) locite etc.
    Bored sleeve for a 62 mm bearing housing fit. Polished.
    Next I MFG a plug. Tight press fit , locite seal etc. Put handle back on....off to ship!
    More pictures on web page
    Bored out the old bearing surface and MFG a new bushing and installed.
    MFG a plug with a tight press fit and locite /silcone job done
    please visit my webpage:
    http://motorworks88.webs.com/
    more pictures
    enjoy
    eddie
      pictures...
      work area
      careful cut tool ! lol
        Nice repair MW, what material did you use for the bushing?
        Tim
          Nice Post Motorworks. And good to see you posting again.
            Hi Thanks
            Tim the material was a scrape of 4140 tube left over from an earlier job that day
            Sasquatch....Being a one man shop and busy it's hard to post , but I'm always looking here
            and you guys have lots of talent. (wish some of you lived closer...lol could use a hand now and then)
            eddie
              burp
