sharp 1340 j
  • sharp 1340 j
    anybody have a a manual for a sharp 1340 j model? cant read the front panel and the 1-8 knob wont turn. KInda hard to cut threads without
    this info. HELP!!!
    thanks
    I assume this is a lathe.
    Can't you figure out the pitch by engaging the half-nut, then follow down a wooden dowel or other with a pencil on the carriage? Measure the pitch of the pencil line over several inches. Repeat for all settings. Make up a chart or label.
    You may also be able to find a photo or other online that shows the panel.
    If ignorance is bliss, why aren't there more happy people?
      there is a place sharpmachinetools.com that has brought machines in and sold them under their name, maybe they can help you
        Contact details for Sharp Industries, who hopefully should be able to help ? :-
        http://www.sharp-industries.com/contact.html
        Doesn't answer your question, but might be of interest - a parts book covering the 1340F :-
        http://www.sharp-industries.com/lathes/1340F1440F1440V.pdf
        Cheers
