I had a recent score of 2 of these grinders, apparently they're what Dremels want to be when they grow up. A neighbor found them clearing someone's basement and they were mine for $20. Unfortunately they've both got 1/8 collets, and this device is pretty obscure, though highly thought of in the few references I found, including a couple of post where people paid hundreds just for the collets! But the name of the damn mfr, Precise, makes it almost impossible to get good search results. HSM's search engine throws the term away as too common!
I'd really like some 3/16 & 1/4 collets, and it looks like I'll need to make them. Any advice on what steel alloy, and what, if any, treatment is needed? I have a .020 slotting saw that should do the trick after the lathe part. I suppose I'll have to make some kind of indexing block for it, don't yet have any indexing equipment.
For the curious, these would be useful for renovation work, where I do not have a compressor with the CFM for an air die grinder. I used one today with a 1.25 cutoff wheel on a toilet mount screw that was too high. Cut it like butter. I also have extensively used my Dremel with a small sanding drum to cope MDF moldings. Much faster than a coping saw and rasp.
