Originally posted by philbur
View Post
Higher voltages makes it easier to overcome insulation properties (skin) and in extreme high voltages it even overcomes the insulation properties of air - nutherwords you don't even have to come in contact or be anywhere near it and it will make the leap - try that with 110,,, the higher you go - the more likely the current will be able to make the jump - be it between your skin or the airspace between you and the high voltage,,,
flashlight batterys have way more than just milli-amps - but you don't hear of too many people getting electrocuted whilst changing them now do you??? ahhh so it's a voltage thing ain't it? brilliant deduction.
