Milling after waterjetting?
  • Milling after waterjetting?
    I'm planning to get a part cut by waterjet oversize, and then I will mill it down to size. Does waterjet leave a layer of embedded abrasive particles that will dull my end mills?
    Not that I'm aware of.
      It leaves a layer of rust on steel, and rust is somewhat of an abrasive (rouge).
      I don't think much of the entrained abrasive is left, especially if you brush off the rust from the edges first.
        Hi,
        The limited experience I have with machining water jet cuts, (reworking slightly oversized parts), indicates no difficulties with wear. And I haven't ever bothered with cleaning the surface as J Tiers suggests. Though that may be a good idea and certainly won't hurt.
        dalee
