How a flyball governor works
Nice demo. What is not talked about is how these governors were linked with other, manual speed controls to allow setting and then controlling a desired speed. It would seem that some sort of linkage that would allow the two to be added together would be needed. That may be the real genius here.Paul A.
Make it fit.
Originally posted by Highpower View PostHence the term running "balls out"..
Originally posted by TGTool View PostHmm. I was told that it came from racing on oval tracks. Hence the similar term driving "balls to the wall" which didn't refer to the governor's balls - unless he was actually driving.
as stated particularly from steam locomotives; "ball to the wall" came from aviation
as early engine controls had balls on the levers and when pushed to the "wall" all
the way forward was full throttle. Dunno if any of it is true but it makes sense.
Originally posted by Shade View PostFrom what I have picked up over the years, "balls out" came from the governors
the way forward was full throttle. Dunno if any of it is true but it makes sense..
Here is a link to the original 3 ball governor being installed on my Webster, but no drawings.
http://www.homemodelenginemachinist....hit-miss-9461/Brian Rupnow
Brian .. that was really neat to see that working .. thanks
And see'in how there seem's to be some "ball" verbiage/history mixed in .. here's a little quickie ..
In passenger train operation .. when the conductor was telling the engr to leave a station ..
he would say .. Hi-Ball !!! Anyone want to gather a guess ?John Titor, when are you.
In general, what I found was that the engine controlled by this governor would be set so that the throttle (be it gasoline or steam) was set to "wide open" by default. As soon as the engine was started, it would attempt to rev up to its peak rpm range immediately. The faster the engine rotated, the faster the stempost of the flyball governor rotated, until the balls flew out from centrifugal force and caused the spring on the stempost to compress and the lever to begin to move. This lever immediately closed the throttle or steam valve and slowed the engine down to whatever constant rpm range was desired. The trick of course, was to find a spring which had the required compression characteristics to compress to a length compatible with the rpm range which you wanted the engine to constantly run at. This required some trial and error I am sure. Once the engine rpm and spring compression reached a stable point, the engine would remain at that rpm, neither rising above it nor falling below it. If a load was applied to the engine, the engine would begin to slow down, and consequently, so would the revolving balls. The spring would sense this movement in the collar and begin to decompress (lengthen) and cause the lever to pivot---Thus opening the throttle until the engine was back up to the desired rpm range. As soon as the load on the engine was removed, the engine would begin to over rev, and the flyballs would fly out under centrifugal force, thus moving the collar and tipping the lever to close the throttle or steam valve, and slow the engine back down to the desired "nominal" rpm. This all happened very smoothly. I would have thought that the action would be very "choppy", but it wasn't--- it was a very smooth and constant operation. I know that if the spring on the stempost was too sensitive, then the engine would "dither", continually trying to rev up and down trying to reach a point of equilibrium where everything remained stable.Brian Rupnow
You start by saying the spring will govern the speed, and you end up by saying a soft spring may be too sensitive and the engine would dither. I agree with your second analysis. The speed the engine will settle at is set by whatever adjustment there is in the lever from the governor to the throttle. The negative feedback involved accomplishes the whole task with no need for any further detail other than the adjustment, and some kind of spring to produce hysteresis - or delay - in the feedback.
On the OT side of this thread, I liked this analysis of the origins of the monkey's fate.
http://www.phrases.org.uk/meanings/c...%20monkey.htmlRichard - SW London, UK, EU.
Originally posted by mikeamick View PostBrian .. that was really neat to see that working .. thanks
