Roller chain size
  • Roller chain size
    I'm trying my hand at making a set of roller starters for my race bike. I found these industrial rollers with sprockets already welded to them, but I can't figure out what size chain they take. The rollers have metric bearings, so maybe the chain is metric, too?
    What size pin fits the sprocket and what is the center distance between pins. Then do a search using Roller Chain Specs. There are several sources of charts showing almost any chain you could every want.
    Many bearings are metric, that doesn't tell where something came from.
      The metric thing was just a guess based on who might have built the original machine and what system they preferred.
      I don't have a piece of chain that fits it so I can't measure the pins. I'm trying to measure the sprockets against the charts on McMaster Carr. Are my pix clear enough to read the measurements?
        You could machine up a pair of test diameters to a size that nests nicely into the gullets. Then measure the distance between the centers of them. That will only take a couple of minutes, and it will give you the diameter the rollers should be and the link centers length. Width- I'd measure it then make sure the chain you get is a little wider. Chances are the right chain size will emerge.
          Stop at the Farm supply(Rural King,Tractor Supply etc) and try out different sizes.
            From the pictures I would say # 40 chain. At least my first try. Their is an odd ball #41 chain but do not think it would be that . And 35 is a lot smaller.
              Kind of looks like 428.
              I/2" pitch with 5/16" wide rollers.
              Have a look at this chart from Diamond.
              http://www.dansmc.com/diamondchainspecs2.jpg
                Take your sprockets to farm supply (as mentioned) or Industrial supplier, they can match it up. If you take the chain number (except 35 & 41) and divide by 80 - it is the chain pitch - 40/80 = 1/2" pitch : 80/80 = 1" pitch. 35 & 41 are a litle different 35 = 3/8 ptch, and 41 is 1/2" but narrower.
                Metric chain is not realy metric but a bastardized imperial to a BS (British Standard). Some Imperial sprockets will run Metric chain, some not.
                Patrick
                  Looks like 0.625" or 5/8" pitch to me.
                  ANSI and BSI chains differ in inside width and sometimes roller diameter for a given pitch.
                  Paul Compton
                  www.morini-mania.co.uk
                    Hi,
                    There are two main standards. British Standard Roller Chain and American Standard Roller Chain. My findings are there is not a Metric standard (yet anyways in common use) as such; just that the dimensions of the two standards can be "converted" from Imperial to Metric.
                    These two links cover most of the sizes for both standards; but are missing the "magical gotcha" for #40 vs (the smaller) #41.
                    http://www.transeals.com/transmissio...sprockets.html
                    http://www.transeals.com/catalogues/...ide-Metric.pdf
                    Here is link that contains #41 and #40 in size order:
                    http://www.gmtel.net/web/drittmer/Te...r%20Chains.pdf
                      ANSI #40,I've worked with a few miles of it.
                        Sorry for the slow thank-you. Since I'm far too lazy to fire up the lathe, I laid two 5/16" bolts between the teeth (they fit perfectly) and measured outside to outside. Then I subtracted the diameter of one of the bolts. It came out to exactly 1/2". Ordered the chain and it was just right. Thanks!
