LPS Rapid Strong Steel Renewal Composite, Any One Remember It????
  • LPS Rapid Strong Steel Renewal Composite, Any One Remember It????
    I've had a tube of this stuff PN#60155 in the shop for years. This was the two part mix. It had about 5 min. working time and was sort of self leveling. I just used up the last of it and found out that LPS no longer makes the stuff.
    Does anyone know of a similar two part product???
    JL..................
    one of these should equal http://www.grainger.com/Grainger/epo.../N-84wZ1z0qsj0
      The toughest two part mix I've ever used is PC-7. It's not five minute, but I think PC makes a range of products. They probably have a similar formula to what you've been using.
        Belzona is the only stuff to occur
        http://www.belzona.com/applications/engines.aspx
        Mark
          Even the Navy used this stuff: http://www.devcon.com/products/produ...Metal%20Repair
          Of course there's always JB Weld.
            That Belzona is some bad a$$ stuff. Buddy of mine brought home what was left of the cans after a pump reline. The Belzona had ceramic filler and would eat a grinding wheel for lunch.
