All I want to do is put a 12x4x1/2 piece of CRS on the mill and run a slitter saw down its length so I can have a 12x2x1/2 piece and a leftover a bit narrower than that.
I was using a brand new sawblade from Grizzly. First I tried a slow rpm and all the saw said was "whap whap whap I don't feel like cutting whap whap whap" so I dialed the VFD up a notch and it went "wheee" and although I didn't see any swarf come off it did seem to make a slight impression in the metal (not like it was cutting, but more like it was trynig to rub its way through the bar). But at the same time it turned into a glowing spinning disc of blues and yellows and when I added more coolant it erupted in a giant mushroom cloud of steam and smoke and when it all cleared I got this:
I did make sure that I had the blade oriented correctly, not trying to cut backwards. I had everything tight as could be. For now I just turned the piece 90 degrees and I'm plowing the cut out with an end mill but it sure would be nice to be able to use a slitter saw like the grownups do. Any advice would be appreciated.
thanks in advance
Joe
thanks in advance
Joe
