I purchased several of these (http://www.imperialgroup.ca/railingcolumnsfencing.cfm) to do a front porch makeover. They will be used decoratively, not structurally. Each square column is fabricated from two "U"shaped pieces of aluminum that are 9 feet long and about 1/8 inch thick; these pieces snap together using a tongue & groove joint. Two of my existing columns abut the brick; hence, I only require one "U"section to cover them.
My problem: the tongue side of the half-column is longer than the groove side. I need to trim (a rip cut) the tongue from the material so that the column will be oriented correctly. I have an assortment of saws & blades that are capable of doing the job (hand-held jigsaw, reciprocating saw) but I expect that the cut would be too wavy - even on one of my best days. Could this material be cut using a 10 inch woodworking table saw with a carbide tipped blade? It would have to be at full speed (~5300 rpm) since I have no way to slow it down to imitate a cold-cut saw. Number of teeth? If a high tooth number is required (40-60) I could purchase a blade for a portable saw (7-1/4 inch diameter).
Any/all ideas appreciated. Thanks!
