Cutting Aluminum Columns
  • #16
    Originally posted by lbhsbz View Post
    He forgot to convert inches to feet on the thickness.
    Yup
    Sorry about that
    Frank
    • #17
      You can cut it with any wood cutting tool. What ever will work best for a piece of high density wood will work on the aluminum. Lubricate the aluminum with wax along the cut line and follow all the other safety instructions.
      I should point out that also includes a router with a guide.
      • #18
        +1 on the wax lube
        Michael
        • #19
          Just out of interest....has anyone tried a Dual Saw? (Contra-rotating blades).
          I am guessing their TV advertising has saturated other parts of the world too.....
          I have no desire (or need) to get one, but the "no kick-back" does seem like a good safety idea.
          http://www.dualsaw.co.nz/
          • #20
            The demonstration video shows horrendous chipping on the underside of wood. This alone makes me extremely doubtful of its usefulness.
            12" x 35" Logan 2557V lathe
            Index "Super 55" mill
            18" Vectrax vertical bandsaw
            24" State disc sander
            • #21
              I replaced three front stoop posts with exactly the same aluminum posts as you described (U shaped, snap-together) a couple of years ago. They were not that expensive and very easy to assemble and install. I can't see how you could come out ahead in time and material expense by making them yourself. Also, I think it would be hard to get as durable a paint job as that which comes with the purchased ones. If you are doing it for the fun of it then more power to ya but I took the wimp path and just bought em.
              • #22
                Got the job done. Used a 7-1/4 inch 40-tooth blade with my portable circular saw (usually a 10 inch blade but did not have a high tooth count blade for it). Set up a ball-bearing outfeed table to add support. Worked great!
                Thanks for all the ideas & support.
