I think I found my stand! Pics to come.
DIY slip roller, tubes or solid?
Originally posted by 754 View PostIs that a working shear ? I have same one 30 inch.. Brown Boggs I think.
Yes it works if that is what you are asking. I got it for scrap price because of a broken head which you can kind of see in the pics where I welded it back together. I don't use it often but there is nothing like it when I do need it and use it. It is a 30" as well.
As for the roller set up on it, I used two sections of box tube to raise the roller so the shear is still usable with the roller on top. I could lower the roller to just one box tube section and still use the shear but visibility and work are under the roller would be tight. If I have problems I can easily just go down to one box section later on.Andy
I would not do it if the shear works. Need my face over it to line up my cut line.
Here is what worked for me, I got a set of rolls about 22 inch, mounted on a 2x10 board.. pull it out and clamp to bench and use it. Might I suggest a 2 x 12 metal tubing base.. could that work.. clamp to a bench to use..
Originally posted by vpt View PostIs this a bad idea?
g]
great project btw.....I'm enjoying watching the buildin Toronto Ontario - where are you?
I didn't get much time but I did get a bit done today. Picked up a couple sprockets and hubs and turned the ends of the two driven shafts down to fit said hubs. I need to drill both driven shafts for grease zerks yet. Then I'll reassemble the whole bit, weld the mounts, and give a test maybe (hand powered).
Using all of the atlas again for these rollers. Had to unbolt and let the leadscrew out to have enough carriage travel. Also had to back out the compound all the way to get the remaining travel, I used the compound to do the turning on the ends of the shaft as the carriage was right on the end of the gear rack.
Originally posted by Mark Rand View PostIt really looks as if you need to arrange some gearing/belts/chains to make it into a set of treadle powered slip rolls.
Originally posted by 754 View PostI would not do it if the shear works. Need my face over it to line up my cut line.
Here is what worked for me, I got a set of rolls about 22 inch, mounted on a 2x10 board.. pull it out and clamp to bench and use it. Might I suggest a 2 x 12 metal tubing base.. could that work.. clamp to a bench to use..Originally posted by Mcgyver View Postyes imo, like 754, I need to be able to look straight down the blade to line up a layout line. My shear is stacked with stuff because I use it infrequently, but its stuff that is light enough to easily move when I need the shear.
That is a good point about the cut line. But it may be possible yet. Like I mentioned I haven't welded the upper and lower square tubes together yet. If I move the upper square tube and mounted roller back away from the shear head on the lower square tubes I may be able to get a line of sight strait down to the shear line. Looking back at the picture I posted earlier it does look like there may be enough room there to accomplish this. I'll have to check that out tomorrow.
Also, I made sure this deal would bolt to the shear in existing holes. If I had to drill more holes or couldn't remove the whole deal when needed I wouldn't have considered using the shear.
That is exactly the input/comments/looking out for a guy I am looking for! Thank you guys!Andy
Originally posted by mattthemuppet View Postfabulous, love the pictures. This thing will be awesome when you're done. I particularly liked the recent picture with the slip roller on the lathe, right at its very limitAndy
Drilled the grease passages, tapped holes, installed zerks, cut keyways.
Cleaned and assembled everything, aligned stuff, and tacked in place.
It was at this point I realized I don't have anything I can roll.
One of the grease passages on one end of a roller won't take grease. Not sure whats going on, I blew out and checked for light threw all the passages before assembling.Andy
Might be stuck ball in the grease fitting. I had a few of those come in new pack. I'd just replace the fitting with another one and see it that works.
Nick job and great pictures. I'm just now getting caught up with this thread. It's almost as long as one of JD's videos.
