Hi Everyone,
This is just a quick post to show that I have not fallen off the earth! I was all set to post this in the 'Shop Made Tools' thread & then I thought that it would be better here seeing as how I may not be able to get back here on a regular basis for progress reports etc.
I never liked the ‘spindex’ fixtures because the index plate is so close to the spindle nose & it is often in the way of the milling/grinding spindle. I always thought that they were designed backwards for the small stuff I often do.
Long ago I had the idea of turning the spindle around, but finally had the chance to do it & incorporate a dividing worm while I am at it.
Here it is before the worm wheel/index assembly is pushed all the way on:
I also slotted the top & added the clamp screws so that the center height doesn’t change when clamped. In the new front there is a needle thrust bearing w/hardened washers. This is covered with an aluminum cover sealed with an O-ring.
The back of the spindle is threaded for a bearing adjusting nut so can I obtain zero endplay:
After today’s work, this mock-up shows the how the worm will engage the worm wheel:
This is a photo of the CAD drawing to show how the mounting bracket for the worm will allow it to be disengaged for quick spacing with the index plate. I change the drawing as I make & fit the items:
This setup is going on a small horizontal mill for cutting clock gears & I didn’t want the heavy dividing heads that are on the market today. Plus, this will allow the use of 5C collets & even will now have a threaded nose for chucks, faceplates etc.
I have more photos & will add more, but I am still pressed for time w/work required on my house
