My new to me Atlas MF horizontal mill has a coolant reservoir inside the column. It has no drain hole and the pump can't suck the last cup or so out of the bottom. The only way to empty it and change coolants is to remove the pump and reach inside with a rag to soak it up and wring the rag out....yuck.
So in a general home use environment, where I will be cutting steel, aluminum, cast iron, and bits of unidentified materials, is it possible to use a single coolant for all. Could it be left in the sump for months, even years without going rancid or bad?
