I have a big project I am building for home. It's an automotive scissor lift that sits down flush with the top of the concrete when its down.
The problem is I am copying a few design bits from different manufactures and want a pivot piece that helps the scissor raise from being completely flat so it's not stressing the unit trying to Greg it to open. Please bear with my descriptions as I don't really know what stuff is called.
Here is a pic of such a lift. The part that the cylinder rod pushes against has a roller on the back side and the unit pivots on the main center pin to help lift open.
I must be dumb and dumber's brother because I don't see what keeps the pivot from continuing to travel about the center pin until the ram comes into contact with the center pin.
Hope this makes sense...I don't see anything that stops the rotation of the pivot.
Can someone explain this?
Thanks. Jim
Thanks. Jim
