Quick question re : e-clip grooves
  • #16
    If I only had a few to do I'd just slow the lathe down and grab a screw slot file.
    • #17
      Schoolie--Yep--That's what he tried to sell me.
      Design engineer
      Barrie, Ontario, Canada
      • #18
        I picked up my e-clips today. They are 0.024" thick. I have a hacksaw blade that measures .028" thick.--A match made in heaven!!! Does anybody have a good suggestion for a holder? If not I can blodge one out of a chunk of mild steel.
        Design engineer
        • #19
          Well Dang!!! Why didn't somebody tell me how easy this was?-Wait!!---Maybe they did---!!!! This is a really hokey set up, kinda like running with a pointed stick---but it worked great. I put what I considered a reasonable cutting edge with about 10 degrees clearance rake on the hacksaw blade, squeezed it in behind a short piece of cutting tool and ran the screw thats on the far end of the holder down onto a double thickness of hacksaw blade so it wouldn't slip backwards. Cut the dandiest e-clip groove you ever seen. Don't try this without adult help----Don't try this at home---Yada Yada Yada--
          Design engineer
          • #20
            I never would have thought to use an old hacksaw blade but it looks like it filled the bill quite nicely though. Good to see it worked out.
            Like some of the others had suggested though I've always used HSS bits ground to suit whatever width and profile I need whether it be for a snap ring or O ring. The two pictured below have a width of .020" and .055". The groove in the 1 3/8" shaft measures .035".
            The larger of the two tool bits also comes in handy as a cut-off tool for tubing.
