punch & die build (video)
  • #16
    If the stripper hangs up, the hole is rubbing on the punch. If the clearances are right, the hole should "break" just clear of it so that it won't hang badly.
    Easy to say, takes some work to make it happen
    • #17
      A simple bridge stripper would be better ith a piercing punch, like
      http://www.jetro.go.jp/philippines/t...mping_dies.pdf
      Press looks too slow to use spring stripper
      Mark
      • #18
        If it is a hydraulic jack-based press, it;'s pretty weak on the pull-out. I don't know if it would really have ANY pull-out force. A lot of those have pull-back springs....
        That could explain a lot.
        • #19
          Punch a kitchen sink sponge. (The ones that are hard
          before you get them wet).
          Put the sponge on the punch, above the stripper plate.
          Oil the heck out of the sponge, and it keeps the punch
          lubed for many strokes. Saves oiling all the time and
          less mess as well.
          --Doozer
          DZER
          • #20
            Originally posted by bborr01 View Post
            Oh, I thought that when Jaakko said that the stripper plate is fixed in relation to the punch, he meant that the stripper plate was fixed in relation to the punch. I have spent a fair amount of time servicing high speed carbide progressive dies and have a pretty good understanding of how they work, although I have never built one from scratch.
            Aha, read my post again, sorry for the misinformation. It should have read "as opposed to the punch", meaning the stripper is fixed to the die or is hanging from the upper side of the press solidly so that when the punch is drawn, the workpiece stops against the stripper plate and the punch is withdrawn from the work.
            About that picture, yeah, someone had a copy&paste mania It should be without the plate on the right.
            • #21
              If money & time were no object stripper plates can be spring loaded and guided and guide the punch. The super high production dies I have seen/repaired had guided strippers and punches and gas cylinders for springs. The gas cylinders were more to hold the stock flat that to strip. These were 12-15 station progressive dies.
              Brings back great memories, back when times were good.
              Jim
              So much to learn, so little time
              • #22
                Great video Tony. Please in the future don't make things look so easy. It might prompt some of us lesser mortals to think we could actually do it ourselves! I really enjoyed the video. Thanks for taking the time to put it together.
                • #23
                  wow thanks all. this whole punch/die business has a lot more up it's sleeves than I saw coming.
                  dare I say 'can of worms'?
                  the reasoning behind the punch-mounted stripper was an attempt to make the punch as versatile
                  as possible. meaning if i need to punch a hole in the middle of a 24" x 24" sheet I could.. with a die
                  mounted stripper .. well it would get ugly.
                  I realize that a punch/die set are for very specific conditions: one hole size (obviously) in one material
                  thickness.. and probably in one specific location for the job at hand.
                  I just don't have that specific a need -- and quite frankly was more just having fun.
                  Now that I have 'the basics' it'll be a lot easier to make up punch/die should a specific need arise.
                  I think I learned alot here and I thank everyone.
                  Next step: deep drawing. 3" deep. (kidding!)
                  Tony
                  ps the press uses a dual acting cylinder.. I think I get something like 18tons on the return stroke.
                  • #24
                    Tony
                    Folks who run Weideman or Strippit machines have lots of tooling.... and can select punch die combinations to suit. It isn't always one punch per die, they can be mix/match combos to get the clearance needed for the proper "break". That ought to go with the material thickness.
                    If you have a dual action press then a fixed stripper will be no problem. (as long as you clamp down the die solidly)
                    • #25
                      Reading Black Forests post reminded me, i didnt say what a great job it was, well done, perhaps with a little scavanging a dual acting cylynder could be fitted to your press, like off a mini digger dipper, with a spool valve you could get powered return stroke, maybee handy for streching things etc, parsell minidie had stripper washers, uou just stacked them up as needed, long time ago rhough.
                      Punch stripper clearance may be a tad tight, how about a double chamfer to stop it crabbing on the punch? You know on the ID.
                      Regards
                      Mark
                      • #26
                        As I said earlier, you can attach the stripper to the upper half of your press, so it stays solidly in place just above your workpiece and the punch goes through it as usual. This wau the stripper doesn't come in your way and doesn't require springs.
                        • #27
                          Wrong! Even with correct clearance the hole never clears the punch. You have to strip it!
                          • #28
                            It won't pull out free, no....... But with correct clearance it won't hang up solidly.... and take a sledge hammer to remove the material from the punch.
                            When the "break" has score marks through it, you know you have a problem......
                            • #29
                              I'm glad I found this thread and saw the video. I may try to make a punch and die set for the small motor laminations I have been considering. It will be for thin steel, perhaps 0.013" thickness or even as thin as 0.005 or less. I'll start another thread for the details and discussion, but seeing this is rather inspiring.
                              USA Maryland 21030
                              • #30
                                Agreed, real nice video, thanks for posting this.
