Hard to machine alloys myths
  • #16
    Ah, AMPCO coppers <3 Have had the pleasure of turning and threading that stuff a few tens of times, making die casting machine pistons. Machines just like prehardened stuff, but oh the fun of getting an inside thread in to it...
    • #17
      Started out as a machinist in the Navy and consequently machined a lot of Monel & Kmonel using HSS cutting tools. We had a very good supply of Momax blanks, but a very limited amount of cemented/brazed carbides and carbide inserts were unheard of. As the OP said Monel & Kmonel can be machined very successfully with HSS tooling as can stainless. One just needs to pay attention to tool conditions and cutting speeds/depths.
      Another poster cited a job where he could not see the surface he was cutting. It sounds like he had one of those nasty set-ups that was going to give him grief no matter what the make-up of the material or cutting tools.
      Of note we made cutting tools using a nickel based spray welding process which we used to cut Stelite (sp?) valves & valve seats. They were suppose to only be ground, but we did quite a few with our shop made tooling.
      • #18
        [QUOTE=Martin0001;879851]
        "Particular troubles are with securing good surface finish
        These observations do not apply to F/C steel."
        For the life of me, I can't place F/C steel. Please help!!
        I know I'll think of the answer an hour after I post this.
        • #19
          [QUOTE=flutedchamber;880114]
          Free cutting mild steel, ive only made resulpherised and leaded, we used to get a couple of tickets to present in the canteen for free milk when making leaded steel!, as if that would help. Either way makes small chips. Adding sulphur to steel is fun too, make sure your up wind of the ladle, very nasty fume.
          Mark
          • #20
            [QUOTE=boslab;880123]
            Mark
            Thank you.
            • #21
              As previous poster have said, F/C i s freecutting steel, type of mild steel and contains lead or/and sulfur to make it such.
              Nice material in the shop.
              I might add that due to various regulations use of lead is discouraged and there is a different type of freecutting steel which contain tellurium instead.
              It is rather a higher shelf product.
              On the other hand freecutting steel doesn't weld well.
              • #22
                There's a difference in cutting this stuff in a home shop and having to do production on thousands of pieces. The people that make inserts have done yeoman research so that a factory running exotic alloys isn't changing inserts or grinding tooling every tenth or 100th part. This is important when there are tens of thousands of parts to make.
                • #23
                  Despite all warnings about "mystery metal", the reality is that we ALL have it and we ALL use it. We do not need material certs for most all of what is done in our shops for our own purposes.
                  As for "myths", I deny that the idea of hard to machine material is a myth. It depends on the machine you have, however.
                  And I declare that anyone who says it's easy if you do it right is boasting! (Either about their machine, or their expertise)
                  Of course if you do everything right it is better. But some materials will wipe that wonderful hand-honed sharp edge right off of your HSS cutter in a short while.
                  If you EVER let the now-dulled cutter "rub", and it WILL rub as soon as it dulls enough, then many materials will become as hard as the hobs of hell, perhaps even "laughing at" the puny carbide you think may cut through. The cutter can dull very quickly in some materials, HSS may last less than one "pass" across the material, no matter HOW sharp you make it.
                  If the cutter ever DOES rub, most likely you will find out about it when you decide to sharpen it, and find that it dulls and rubs AGAIN in 2 seconds, because of the hard area you just created.
                  Now, if you have a large and powerful machine, this will not be a problem for you, because with enough power, you can cut some materials with a factory-fresh unsharpened HSS blank. Dulling is a nuisance, of course, but you have many more choices. And you will not have any problems with "spring" of teh machine, which can cause issues in work-hardened areas of the piece.
                  With a large and heavy machine, you dial in the cut, and the cutter moves in that far, no questions, no problem. Not so with the usual Atlas, Southbend, Logan, or maybe some Sheldon machines.
                  1601 2137 5683 1002 1437
                  • #24
                    It is not claimed that "hard to machine alloys" dont exist.
                    It is claimed that few common (and less common) materials, namely stainless 304 or 316 or titanium (Ti6Al4V), Monel, Hastelloy, in particular B3 hastelloy and few others are not in this class, despite of tons of whining in professional community.
                    Usual reason of such sad experience is:
                    1. I cannot be bothered to sharpen my tools.
                    Machine is strong, I can turn with a nail.
                    2. Stubborn, often mindless application of rules known to be correct for a carbon steel.
                    3. Air gap bearings
                    4. Carriage sliding down its bedways like a drunk man in the fog.
                    5. These materials are very tough, everyone says that they are tough, even my customer knows it, so he will pay more and I will laugh all the way to my bank.
                    Of course few materials are troublesome and Inconel or Steallite are between such (as mentioned by others).
                    But common stainless?
                    • #25
                      WHICH "common stainless"?
                      Some are an absolute dream to cut, clean and easy, others are a real pain.
                      Then some ordinary-seeming stuff, like hot-rolled high carbon materials, will humble you if you let up for an instant......
                      4140 will dull HSS in one pass of a few inches, especially if you are pulling blue chips, but thankfully doesn't harden as badly as some other materials.
