I have a Harbor Freight air compressor:
http://manuals.harborfreight.com/man...5999/95498.pdf
After a few years it would not reach the full 100 PSI pressure and I found that the check valve was leaking. I took it apart and found that it had a soft silicone valve that had become distorted by the spring, and I figured that a replacement from HF would have the same design flaw. So I decided to try and fix it by making a better valve seal. I was going to use brass but I did not have any, so instead I used a piece of Delrin plastic rod. I also used a counterbore to clean up the seat in the valve for a better seal. Here is the piece where I was using a boring bar to create a pocket for the spring:
Here is the disassembled valve:
I found that the OD was too large to fit in the brass cap, so I had to turn it down more. The small end was too small to fit in the lathe chuck, so I used a mini-lathe chuck to hold it, and the live center to keep it from wobbling. Here's the setup:
I used an O-ring in a small groove on the short part, but it didn't seem to seal very well. So I added a larger O-ring and it seems to work reasonably well, testing it by blowing into the threaded connector that goes to the tank. It's still not perfect, but perhaps with higher pressure than I can produce (even though some people have called me a blow-hard
), it might work well enough.
This was to some extent a practice project, and I might redo it in brass, but I wanted to know if anyone had any experience fixing a valve like this. I might use some soft flat silicone gasket rather than the O-ring.
