5C Spin Indexer
  • 5C Spin Indexer
    Hi Guys, just a notice to let you know Tom Lipton , Oxtoolco on YouTube is making
    some videos on the 5C Spin Indexer to index 127 indexes and any reasonable number
    you would like to make. I imagine there are a lot of you who have 5C Spin Indexes.
    There are only about 7 parts to make and they are all easy. So join Tom on
    You Tube i think you will enjoy his videos.
    Also would like to say I just ordered from McMaster Carr tonight and the order was
    processed , so it looks like McMaster Carr is shipping to Canada now. I tried making
    this post earlier and it never showed I hope i am doing it right this time.
    Wayne
    wayne101
    Hey my eastern Canuck brother....
    Thanks for the tip!
      I don't understand the U-tube bit. how about a link?
      I do know what the bit is about but don't have a clue how to go about looking for a particular one.
      ...lew...
        Welcome Wayne101 from another Canuck.
          http://www.youtube.com/watch?v=m_VO9...yjrKT4OZne-JNw
          try this
          Peter
            As a subscriber to Cutting Tool Engineering Magazine where Tom Lipton has a monthly column dealing with the aspects of manual machining in the modern machine shop, I'm sure I'll enjoy this video later today when I get time to relax.
            Welcome Wayne, and thanks to Peter for the link!
              Originally posted by ptjw7uk View Post
              Thanks. Watched the whole thing. He needs a bit of "production" help. :-)
              One big problem I see with the design: The index pin does NOT move along a radius of the index plate.
              thus the angle of the second and third row of hole/holes is not the same as the first. ie. there will be
              an error in the spacing of second set (and last) from the first set. I havent done the math but from
              the arc for swing of the pin it could be significant. I see a possible (it's going to difficult) way to
              compensate for this. The pin would have to be moved the correct amount along the arm to compensate
              for error. It would be a very small amount and would require a wider arm with three pin locations.
              ...lew...
                Maybe I missed it, but you still have to be able to divide 127 to make the plate.
                Bob
                  Bob
                  I think the idea is to only have to do it once. But I wonder just how accurate the initial division has to
                  be. I don't remember what he used (I'm not about to go back and suffer through all the BS to find out)
                  but I get 2 deg, 50 min. 4.7244.... sec. :-) per step. So depending on how fine the adjustment on the
                  dividing head used there could be an appreciable error buildup around the circle.
                  So, how many decimal places are actually in use by the manufacturers that make 127 tooth gears????
                  ...lew...
                    Bob
                    I think that this is just the first in a series & that more instructions are coming.
                    Here is my idea of how to deal with the question of eliminating errors when changing to different hole circles. This shows two possibilities for a mount to be screwed at either end depending on which end you wish to mount the index plate. It shows a .750 wide groove & .375 slot at a 20 degree angle for a sliding block that would have the index pin in it.
                    Of course the slot has to be on a radial line from the spindle center & the siding block has to fit snugly. None of these details are cast in stone so anyone who wants to try this should be able to figure out any other details.
                    Best wishes to ya’ll.
                    Sincerely,
                    Jim
                      Yes- the swinging index arm will cause an error. This could be accounted for by offsetting each subsequent circle of holes, or by making the index arm as close to tangental to the circle, or by redesigning it to use a watts linkage
                      allan
                        Holy **** - are you serious? This changes everything! Please tell us whether or not this stuff shows up!
                          Peter
                          This guy that made the video is a waist of time he could cut the video down by 2/3 if he would get organized. The member here did a much better job with
                          modifying the spinn indexer. Oh well some just like to be on video
                            If you had read the entire thread, you would have found that they canceled his order the following day.
                            James
                              This should be more accurate:
                              Note: Only somewhat to scale
