Pillow blocks
  • Pillow blocks
    I'm needing to get some pillow blocks and have seen the standard one with set screws as part of the whole block. Then there are these
    http://www.ebay.com/itm/231030445971...84.m1423.l2649
    That have a separate collar. What is the purpose of this separate collar? My application will not have any speed involved. It will allow me to tilt a table top 90degrees.
    Thanks for the help.
    If you would post your location, I might have a pair you can have.. Bob.
      The collar is an eccentric that locks/tightens up on the shaft so the shaft turns with the bearing.
        The collar is just a free bee I guess.
        Some bearings use an eccentric locking
        collar to fix the bearing to the shaft.
        This is not one of those.
        I see nothing special.
        --Doozer
        DZER
          +1 for Doozer. That listing is a lost leader for the silly shaft collars....the guy knows nuttin and he's phishing! Where are you and what size do you need?..I have a box full..brand new and I'm getting too old to use them!
          Stuart
            I updated my profile. I'm located in Denver.
            The collar looked out of place since the eccentric setups look quite different. I am looking for 1" pillow blocks and need about 4 of them.
            Thanks for clearing that this is just a useless collar with a setscrew.
              I've used pillow blocks that have an eccentric collar that can be rotated to jam the shaft in the bearing to insure that the shaft and inner race turn as one.
                I have seen those but they are pricier that the standard ones.
                  This place has a good selection and good service. http://www.surpluscenter.com/
                  Byron Boucher
                  Burnet, TX
                    VXB Bearing has them for the same money-
                    http://www.vxb.com/page/bearings/PROD/kit920
                    If you want US made surplus try Youngs-
                    http://youngssurplus.com/bearings.htm#Pillow Block
                      I looking for pillow blocks a little while ago and I found this company with good prices and free shipping:
                      http://www.fremontindustrialsupply.c...ock/Categories
                      USA Maryland 21030
                        While this ad contains the information that this is an "import product", meaning China-made most likely, I don't like the fact that the company name begins with "USA" in big red caps. Not saying that China-made automatically means bad, just don't like what looks to me like an attempt at deception.
