Gentlemen,
It's been awhile since I posted anything so I'll update you on my current project. I won't post the whole build as it's on another forum but I will give you the highlights of the build so far.
For this winter's project I wanted to build another engine but this time in a configuration (cylinder count) that I don't have. I decided on an inline six based somewhat on my 4 cylinder engine. While drawing up the plans for it I decided to detail it more so than the 4 cylinder engine. This brought me to the venerable Ford 300 I six.
Working from just pictures I started creating the drawings. The engine will have a .750 bore and an .875 stroke. It will be water cooled, this time through the block and head. It will have a splash oil system as it has proven itself with the 4 cylinder engine.
Before cutting any metal I had to see if I could make the required helical gears to drive the distributor from the camshaft. Trying to make this engine more prototypical I would need the distributor mid block. A fellow on one of the other forums came up with a fixture and method to cut these gears. His name is Chuck Fellows. Along with Chuck another gentleman, produced a spread sheet to spit out the required numbers for P.D., tooth counts, etc.
gbritnell
http://smg.photobucket.com/user/gbri...b8dc1.jpg.html
gbritnell
