3D Printing
  • 3D Printing
    Saw a program discussing Philadelphia's proposed ban on the 3D printing of firearms. That got me to thinking -- I have a project (out of dozens) that I need to make a pattern for. It will have 3 identical parts, plus a few others. I thought about hand crafting 1 master, then making an RTV mold, casting 3 secondary masters, and using them to build up the complete pattern. But a 3D printer could do the whole thing. After a quick search of the web, I found a site with a printer cost comparison chart. Printers start at around $300 for an assembly it yourself kit to $2000+ for a ready to go printer. The lower end I could do.
    So, does anyone play with 3D? Where can I find good how to get started info?
    Kevin
    More tools than sense.
    Do some searching on "RepRap" It's an open source 3D printer project. Building one for $300 would probably be a stretch, $500 would be more like it. Especially for a first machine. My "Rostock" cost about $600:
    http://www.youtube.com/watch?v=OGWXkyn1KeA
    Now I'm working on a "Morgan" which is another odd ball machine.
    I would say look at one of the Prusa variants because they seem to be the best documented/most popular right now. Be warned though, 3D printing can be a mighty deep rabbit hole but it can be just as rewarding as machine work!
    It's actually the thing that has re-ignited my interest in machine work because I'm working to improve the technology.
    Techno-Anarchist
      If all one wants is the finished result, perhaps one
      of the many service bureaus could deliver, whilst
      sparing you the inevitable learning curve/expenditure
      that DIY entails.
      Choosing my battles is becoming more important, ymmv.
        I saw that option on the 3Ders.org website. Thought about it for a while then realized that once I find one use for it ...
        Kevin
          The cheap 3D printers ($300 range) are crap. The people I know that have the spend more time messing with them trying to get them to produce something usable than anything else.
          If you want something to make patterns for molds I would look at one of the resin machines that use a projector. Way, way higher detail. The output is more fragile but since you are recasting anyway it really won't matter.
            As for the ban, that will almost certainly be deemed unconstitutional.
              It (the ban) hasn't passed yet. The first step after is PA's preemption law. Its idiot law -- the machine to lay metal (SML) runs 600 to 900 K. Just the thing your average street thug is going to run out and buy so he can make his own gun. I guess this is just a symptom of America's loss of much of its manufacturing base. People have no concept of how things (name anything) are made. Same goes for where food comes from. Hint -----
              The grocery store.
              Kevin
                Wait until your dumb lawmakers realize what an old bridgeport can do.
                I bet they will make anyone with a drillpress in his basement register it as a gun manufacturing facility.
                FSWizard - Free Online Speed and Feed Calculator
                  3D printing is a little different. I printed out a "Liberator" pistol in .380 and test fired it a couple of times. It is a TERRIBLE gun but it did manage to throw a couple of slugs downrange. The scary part is that it's almost 100% plastic. The firing pin is the only metal part.
                  Took about 8 hours to print all the parts in ABS plastic but the machine did all the work while I was mowing the grass...
                  One thing I learned about 3D printing is that it's about WORTHLESS unless you learn some type of CAD. Once you pick up some CAD skills it's neat to be able to push a button and have the part you've designed made!
                  If you need fine finish parts for casting, etc. That's possible too;
                  Techno-Anarchist
                    Forget castings how do I get a date????????
                    Southwestern Ontario. Canada
                      LOL! Nekkid wimmin are fun to print!
                      Techno-Anarchist
                        Look like you got the breast implants inside
                          Fine. So what equipment did you use?
                          Kevin
                            Home made Rostock Delta:
                            http://www.youtube.com/watch?v=GDO7aP8XSnc
                            http://reprap.org/wiki/Rostock
                            Good robot and fun to build!
                            PM me if you're interested in building one. I'll be glad to help you with parts selection etc.
                            Techno-Anarchist
                              That's an amazing resolution progression from when I bought/built my "maker bot" which did nothing but suck $1500 out of my wallet, dozens of hours out of my life, and drive me into a murderous "wielding a ball peen hammer in a manner unintended by its manufacturer" rage.
                              What's the rough time investment on that? Looks like it might be worth a second plunge.
                              Proud machining permanoob since September 2010
