Material Gloat.
  • Material Gloat.
    That is a 6 foot bed of my Toyota about half way filled of mixed plastics. Most of it is a mix of UHMW, PET, and Acetal. I got it for the cost of picking it of off the top of the dumpster, except for the skid of very large chunks at the bottom that got loaded in with the forklift. Had I realized sooner it was getting thrown out, it all would have gotten loaded. I think I did alright.
    Here's some better pics of the haul.
    Pretty sure most of this is UHMH
    I think most of this is PET and possibly some Acetal. The 2 chunks in the lower right hand corner are PET-P, 1 is 12" x 20" x 3" thick the other is 12" x 20" x 2.5" thick.
    Pretty sure this is PVC, 1" thick.
    I think the middle and the left piles are PET, left is 1/2" thick and middle is 1.25" thick, both 30" plus lengths. The piece on the right looks like maybe UHMW or maybe a nylon, is it pretty big, 12" x 48" x 2.75" thick.
      Lots of stuff to move around and stack and shuffle and move again until one day you say to yourself...what was I thinking!
      Stuart
        Wow!
          Nice gloat!
          I understand that this stuff is expensive - I just wouldn't know the good stuff if it fell on me
          Monarch 10EE 1942
            So is it possible... to build a functioning steam engine entirely out of delrin and teflon?
              Yes You can make a steam engine out of it. You must first make a cold steam boiler with an attached steam super chiller so to as not melt anything.
              mark costello-Low speed steel
                Here I am,hoarding my little milk crate of plastic odds and ends and you show up with truckloads.
                Oh yes you suck!
                  You do suck! I wonder what the retail is on all of that. I'd say @$10K.
                  Randy
                  Do yourself a favor and see if your TV carrier has America One News Network (AONN). 208 on Uverse. It is good old fashion news, unlike the networks, with no hype, bias or other BS.
                    I use white plastic all the time for "things". Amazing score you lucky sob!
                      I need to make two centering cones for the line borer that I am building.
                      Each one about 4"to 6" dia. and around 2" thick.
                      Got anything in about that size that pile you are willing to part with?
                        I will take a look for you, I am not sure what is there for stuff that thick. Would you be willing to glue up 2 pieces of the 1" thick pvc (the sheet leaning against the truck) if I don't have anything else?
                          Sure thing!
                            I'd offer fair money for UHMW or Acetal/Delrin rounds in the 3 to 4" diameter range, use the stuff all the time. Flats not so much. That was one hell of a score however...
                            YOU SUCK!
                            James Kilroy
                              You did good.. That looks like at least 1k of plastic.. I know because I buy drops for projects and one sheet of 3/4 x 12" x 6' runs a little over 100$
