Printer scale problem solved
  • Printer scale problem solved
    In an previous thread I was asking for help making an HP printer print to scale.
    http://bbs.homeshopmachinist.net/thr...r-how-to-scale
    Finally figured it out,it wasn't the printer,but the Cad settings that were wrong.In DeltaCad it turns out you open the program,select file,then select "set print region" and then set the scale to 1:1.Works perfect every time now.Autocad setup was similar IIRC,but brain fade prevented me from seeing it
