Just buy a new element. I have tried crimps, bolts, tig welding, etc. crimps and bolts create thermal issues. The chances are you will be inside there to repair it again in a couple months in the very least. While you are in there check the thermal switches and make sure they are in good condition, I have seen quite a few of these burn up.
Throw it out and buy a new one.
IF you can get a replacement element, they generally come compressed, like a tightly wound spring. Measure the total length of the old element carefully, and then stretch the new one to the same length. Prevents hot spots and such when installed, will last much longer.
Coincidence, last night i was reading a 1954 Pop Mechanics and they mentioned a repair for this. Article stated to fasten the ends together, cover the joint with "Borax" then turn the power on and the joint will fuse back together.
Wonder how well this really works?
Originally posted by YukonHam View PostIF you can get a replacement element, they generally come compressed, like a tightly wound spring. Measure the total length of the old element carefully, and then stretch the new one to the same length. Prevents hot spots and such when installed, will last much longer.
Originally posted by sasquatch View PostCoincidence, last night i was reading a 1954 Pop Mechanics and they mentioned a repair for this. Article stated to fasten the ends together, cover the joint with "Borax" then turn the power on and the joint will fuse back together.
Wonder how well this really works?Andy
Looks more robust than our European offerings we have here ..our heating elements are usually in a little tin box about 7 x 3 x 3, but very cheap to replace, can be had for under £10.
Knowing what I know, I would chuck the thing out and if available on your side ..buy a condensing dryer .
As these (in the winter) have a dual purpose ...all the waste heat will heat your house ..meaning you're not chucking the waste heat out of a hole in the wall.
edit ...having said all that, I see that there also European ones that are like a giant cooker hob solid element.
but as for my advice on condensing ones , I'm sure is this is the way to go . if you have expensive electricity in your parts ..UK price is about £0.15 pence per kwh..Most dryers have a 2.0 -2.5 kw heater in them ...so depending on the heat setting can cost up to £0.45 per hour to run with the motor adding to it.
all the best.markjLast edited by aboard_epsilon; 12-06-2013, 10:56 AM.
Originally posted by kbertoson View PostAt one time they were selling a dryer heat vent that sent the heat into the room and not outside.
The problem with them is that you are also dumping lots of water into the house, not to mention the lint that is not caught in the lint trap.Hi, my name is Wilson and I am a tooloholic.
Originally posted by macona View PostThe chances are you will be inside there to repair it again in a couple months in the very least.
Or the TLDR is while you're in there, replace the rear bearing before you get stuck having to replace the whole front of the dryer.
My rear bearing is an oillite bush in a swivel housing ...not on its schedule or anything ..but every couple of years I have to service it ..or it locks into one position in its housing...then the drum locks! ....last time I used ptfe high melting point grease ..its been four years now and no trouble .
The condensing dryers have a container for the water and a removable lint filter . the container, when full, stops the dryer and puts a neon light on .the water container needs emptying every 2 - 3 cycles, the lint filter needs cleaning after every drying cycle.
it has a removable aluminium condenser that I have to remove and flush through every 20 or so drying cycles ...I flush it in the bath because there is enough room under the taps to get it in ..as it I measures about 16 x 12 x 4 inches
condenser part 146.
water container part 346
That heat exchanger above. That I called a condenser ..works in cycles by the dryer taking cold air from inside the room ....so cooling it down ..then after a say 20 seconds blowing cold air through it, it blows the warm air from inside the drum over it ..
You could have a condenser as in the picture hung on the wall further up ..by running cold water through it. maybe using a gas boiler matrix as the condenser.
one of these things with cold water going through it
all the best.markj
all the best.markj
Originally posted by aboard_epsilon View PostThat heat exchanger above. That I called a condenser ..works in cycles by the dryer taking cold air from inside the room ....so cooling it down ..then after a say 20 seconds blowing cold air through it, it blows the warm air from inside the drum over it ..
all the best.markj
all the best.markj
