SO I got one of those wood stoves with the duel motor fans, the engineer that invented this mess should have taken one ride in a twin engine with the rpm's out of sync and he would have immediately $hitcanned the hole idea,,, even though it's cold as hell outside I tore into it to save whats left of my sanity,,,
anyways - got everything balanced as best as I can and just cleaned out the motors little "end blocks" that support the sintered bronze bearings and have that fluffy stuff around it to transfer the lube, im wondering what type of lube one uses, do I have to make a special run for non-detergent or can I just use high quality synthetic car engine oil, or 3 in 1? she's going back together cuz it's 18 degree's here so any immediate reply's would be helpful - thanks
