My used Kabota has a fuel problem. It's starving then quitting. No fuel flow through the filter. New filter even before the problem. Took the whole filter housing off today, and found some fiberous strands in the fuel stut off valve. How did it get there? So to be sure I have this solved, I need to know the tank is clean. The tank is a major PITA to get out. and, it's an oddball shape made to fit here it is. I can hardly see down to the bottom because of the odd shape.
So my plan was to flush out the tank, making sure it's draining well, but I sure would like to know there isn't anything hanging around down there to find it's way to the outlet and block it. I could probably use some duct tape engineering to hook up a hose to get down to the bottom of the tank, but would there be an issue sucking it out with an old shop vac? Don't want to cause some kind of "issue" doing this.
