I just got a Colchester Master 2500 lathe with a fair amount of bed wear. The issue is whoever was running this lathe for the majority of its life left the gap insert on the shelf, or so I believe. There's a couple thou ridge between the bed and the gap insert, enough to make the carriage make a clunk when it hits it.
I haven't yet removed the gap piece to make sure it's not just swarf caught underneath, but the carriage tightens up at the tailstock end of the bed so I'm pretty sure it's bed wear.
I know the real fix is to regrind the ways and carriage but that's not in the cards for some time, if ever.
Is there any way to smooth the transition between the gap insert and the bed? Maybe stoning a small bevel on the end of the insert? I realize with the wear the way it is it will never be an amazingly accurate machine; that's not a big issue, I just want it to not clunk!
