Hello All.
maybe some of the English chaps may be able to help here please.
I have enquired with many vintage organisations but have no informative response.
I was given a con rod out of an English motorcycle dated 1913. it needs some repair and has been welded at the bottom of the big end eye. I would like to know what type of steel this is probably made of before proceeding down any paths to repair.
being this early, it seems industry was just coming out of the wrought iron era. however, there were airplanes, automatic weapons and lots of other engineering requiring steel better then what we call mild steel today.(less than .2% carbon.
1. does anyone know what type of steel a conrod out of a 1913 Truimph would be made of. EG: plain carbon, alloy steel, what type of alloy steel, whether it was heat treated, what was the tensile strength, l etc.
2. were the EN series of steels around in 1913
3. is it possible that the rod was made from EN16 steel. this was a common grade used among english motorcycles for crankshafts, studs and bolts , however I am not familiar with its use as far back as 1913.
I would like to know what type of steel I am dealing with here. I have no idea. the existing rod seems to be very soft, around 30 rockwell C. the documentation I have say the rod is the new improved heat treated steel, but this could mean anything.
Any help and advice would be greatly appreciated.
kind regards and best wishes to all
Bradley
Bradley
