Santa was good to me!
  • Santa was good to me!
    My wife gave me a Rhino 6000 label printer for Christmas. This thing is really great. I can make my labels on my computer and download them to the handheld printer.
    Then what ever I am labeling I can print the label on location. I can also create the labels as I need them in the shop without the computer. Just use the printer keypad.
    It will print labels from 6mm wide to 24mm wide.
    Now I can label all my nuts and bolts bins!!! My drill index so the drills go back to the correct place! All my hydraulic hoses on my various projects. And last but not least I can label all my wires in my control cabinets on some of my projects. It will print on shrink tubes also.
    Life just got better!
    Great! Sure beats a magic marker....Merry Christmas!
      Now tell us what Santa brought to your wife and her sister.
      WI/IL border, USA
        My guess would be a new camera!
        Errol Groff
        New England Model Engineering Society
        http://neme-s.org/
        YouTube channel: http://www.youtube.com/user/GroffErrol?feature=mhee
          You can even use it to label all the parts on the CNC plasma cutter so when you find them again you will remember what they are.
          Plain ol Bill
            Labelers, I think, are often-overlooked aids to bringing/keeping
            order in a work space.
            Modern ones sure make the job easy to get right the first time.
            I remember settling in with the old school Dymo-style way back.
            More than once, the ribbon tape would be nearly finished and there
            would be intense concentration on tapping out the remaining
            characters accurately, hoping not to make a mistake and that
            the ribbon would last long enough to complete the task.
            BF, do you use bar codes? I do not know about whether the Rhino
            can print these, but I am guessing it can. While it used to be
            that information encapsulated in Code 39 or the equivalent
            was pretty sparse, new BC types can be fairly dense.
              Now you can run around labeling everything in the shop with "mine"
                I am assuming that EVERYTHING you own now has a label?
                  What are you talking about Christmas isn't until tomorrow.
                  Southwestern Ontario. Canada
                    Those things are like razors and blades, the real money comes from selling the tapes, but, boy are they handy.
                      Here in Germany presents are exchanged on Christmas Eve. And whereas we are from 6 to 9 hours later than you all in USA it is now Christmas Eve evening here.
                        I gave my wife a set of electronic drums for Christmas. She has always said she would like to play the drums. This present I might even deliver to her sister!
                          It is surprising how handy those things can be. I grabbed a small DYMO 330 USB desktop label printer at work, I intercepted it on its way to the dumpster. I grabbed it mostly just to fool around with, did not really think I had much use for such a thing. I have since found loads of uses for it, and have printed hundreds of labels with it. It found a permanent place on my desk. I'm pretty sure I'll want to replace it once I finally wear it out.
                          The ability to print wire labels and on heat shrink tube will really up the level of your panel building. You will REALLY appreciate that when you come back to rework or repair your wiring after being away from it for a while.
                          Nice gift!
                            Hi Everyone,
                            Merry Christmas to ya'll!
                            Some great tips here that I either use, or now, will use.
                            One that I find handy is to label the junction boxes I have for my 3 phase.
                            I am often moving my machines around as I try to get the most out of limited space. I can just glance at them & know right away which ones are which. I don't have to follow the thinwall to see where it came from.
                            Another one that comes in handy from time to time - in case I get confused (this seems to happen more & more as I get older) This one can really keep me out of trouble!
                            ROFLOL
                            Best wishes to ya’ll.
                            Sincerely,
                            Jim
                              Ha ha! Though I think this would be one of the last things you would forget-
                              Until the last few years, I've been in the dark ages in regards to labeling things. I remembered the dymo labeler and kept an eye out for one. Now what I do is use the mill to make a shallow channel in whatever I want to label, then trim the piece of label to length and round the ends. It looks much nicer being recessed a tad, and you can't catch things on it. Things I've labeled without recessing it look kind of tacky, and labels stuck on in a recess look - well, decent anyway. To be sure, I'm stuck with the spacing of the letters, etc, according to the label machine itself, but it does lend a sort of rugged look to whatever it's stuck onto.
                              For a better look, what I've done a few times now is work up an image of what I'd like the 'front panel' to look like, which sometimes includes markings around a dial- that kind of thing- then have it printed on photo paper. At work we use a kind of 'high grade' contact cement, and that works well enough to stick the artwork down with. I suppose a stick-on photo sheet would work also, probably even better. A few coats of lacquer and the end result looks good. It's pretty cheap to get even a fairly large image printed these days, and what I've also done is make up an image file of names and identifications, then cut them out and stick them on.
                              For a project where there's a front panel, I'm really leaning towards the printed photo stick-on, especially because you can make any markings you want, use any font and size you want, etc.Colors too-
