How times have changed.
  • #16
    John do you remember a short time ago a female teacher was threatened with death for allowing a student to call his little teddy bear mohammedIit caused quite a diplomatic explosion at the time it is funny how angry some muslims are over such things but there we have it. Alistair
    • #17
      Originally posted by John Stevenson View Post
      Anyone know where I can get a 44.53 DP gear cutter ?
      John, you need one more machine for your shop, a CNC Shaper
      A machine where all things are possible !
      Rich
      Green Bay, WI
      • #18
        Changing his name to "little teddy bear" might cause even more problems at the local pub
        • #19
          Many thanks for that but I do have a copy.
          Sad bastard that I am i probably have over 100 books of gears and gearing.
          problem is most contain the same info so distilled down those 100 will probably make 5 or 6 unique books.
          Trouble is there is always a loose gem in most of them.
          Have you got any of the American Gear Manufacturers' design manuals?
          I've got section three, on helical & spiral gears, could lend or sell it to you if of interest.
          Tim
          • #20
            If it's the set in 5 parts then got them all.
            Trouble is often times a reprint carries a different name.
            Got two books here with different names and covers but the text is the same in both.
            • #21
              Dunno, it only mentions 'Section 1' which is mainly mathematical tables relevant to gear design, and 'Section 2' which covers spur and internal gears.
              Written by Earle Buckingham, Cambridge, Mass., Industrial Press, 1937
              Edit - looks as though it's still available:-
              http://www.amazon.com/Manual-Gear-De.../dp/0831131160
              Tim
              • #22
                John, I took your request for help as a rhetorical one, are you actually looking for specific info?
                • #23
                  No think I'm sorted on this one, need to talk to the customer after the holiday
