Jet JBS14-MW - Metal/Wood Bandsaw - Slowing to cut steel
Hey everyone, happy almost new year. I got a great deal on an older Jet Band saw, the JBS14-MW. This saw is very similar to many of the other Taiwanese saws out there from Rockwell, Delta, etc.
This one has an intermediate pulley system that allows it to be run at a few different speeds by moving the belts. However with the current pulleys and set up the slowest speed it will run is 700 FPM which despite being noted as a dual use saw is still way too fast for steel.
I want to get this down into the ~100 FPM range to be able to cut steel. I well run a bi-metal blade with roughly 18 TPI.
With that application in mind, I have a few options:
1. Try to use just a pulley change and utilize that to get to the correct speed. One of the more simple methods but not sure I can get it slow enough by simply doing that.
2. Run a gear reduction box of some sort.
3. Run a DC motor with a controller so that I have variable speed.
4. Combination of any and all of the above.
I am heavily contemplating option 3 and have found a couple DC motors with a gear reduction box already on them as well leading me down the option 4 path. I like that idea so that I have virtually infinite speed adjustment on the saw.
What are folks thoughts here? What have you all done on yours? Can you post some pictures of conversions that you have done? Would love any and all insight. Also, I do plan to also plan to install some brush blade wipers to keep metal chunks out of the tire and would also like to see any pictures of what you might have done there.
Thanks in advance.
Thanks in advance.
