I have a stuck 14N Ball Bearing chuck--the jaws are stuck all the way open. The instructions for disassembly say to close the jaws so they don't get damaged when you press the outer ring off. I can only move the jaws a little bit (they don't even clear the end of the chuck before they jam up.)
What is typically damaged when the jaws are in the wrong position? I don't really have a choice but to force it off, unless you have any better ideas?
Thanks--Mike.
Thanks--Mike.
