I have a piece of fire hose that I want to seal at one end. It's an experiment - don't ask
Actually, I want to inflate a section to test its rigidity properties- but that's secondary. This stuff is a braided tube covered on the outside with what appears to be vinyl or pvc. The inside is similar, but does have a bit of a rubbery feel to it- though it is not rubber. I want to be able to make air-tight seals in it.
The hose lays flat when not inflated, so it would seem the best way to do this is to glue the end shut, and then probably sew a line across it. I tried goop, which so far has stuck to anything I've tried it on, but it doesn't bond well to this material. I tried heat-sealing, but the inside doesn't seem to respond to the heat as well as the outside. I can heat and bond the outside to itself, but that doesn't help me. I haven't yet tried a heat gun, as I would think the heat would be spread too far and the whole end would get soft. I will try that next, though.
What I'd like is to be able to spread a line of sealant on the inside, and then clamp it closed until it cures, then find that it has actually bonded.
Any ideas on what I could try? I realize that not knowing exactly what material this hose is lined with makes it difficult to choose the right stuff.
