Not an emergency. Still have power. But today was the day to exercise the generator, and I decided to test the upper limits of the generator.
It is rated at 6.5 kw. It has 2 duplex 120V receptacles, and a four prong 220V outlet. It also has a set of 8 amp 12v posts, which I have never used.
It appears that no matter how I plug in the electric heaters, when I plug the third one in, the breakers trip.
I have tried it through the duplex receptacles, and I have tried it through the 4 prong 220V outlet/cord.
No dice, when I plug the 3rd heater in, it trips the breaker. I'll try to post a picture of the power panel:
This is an air cooled diesel generator. Like so:
http://www.ebay.com/itm/Aurora-6500D...item230f2e08e5
The engine does not appear to strain when I plug in the third heater, just the breakers trip.
each heater used 11-12 amps at 120 v or ~ 1300 watts.
thanks in advance,
doug
thanks in advance,
doug
