I always understood that one of the advantages of hobs for gear cutting was that you only needed one to do the whole range from pinion to rack, instead of a set of 8 involute cutters. Is this correct?
The reason I ask is that I've got a number of 10mm bore hobs for .5 module and 1.0 module, but they are marked variously '21-25T', 26-34T,35-54T, 55 -134T, 135-RT. They are a quality make, not Far Eastern, unused and in their original packaging marked 'Horstmann Precision Gear Hob' The teeth do seem to vary in profile between hobs.
As my project to construct a small hobber along the lines of the 'Jacobs' self build hobber progresses really slowly, if I mounted these on a suitable arbor, and set the vertical head of my mill over to the marked helix angle, is there any reason why I should not use these with my dividing head to cut modular gears in the 'normal' way, one tooth at a time?
Richard
Richard
