I've had this machine for years now, but never used it. Now I want to. I mostly have figured out how to 'string' it, and it actually sewed a couple of times, but things aren't right. The needle is touching one side of the hole in the foot as it goes downwards, but does seem to go pretty close to centered where it enters the hole in the 'deck'. The needle looks pretty close to straight, and both posts in the machine look straight. Obviously something is off slightly, so I'm going to blame the needle. I will attempt to bend it slightly so it clears the hole in the foot. As it is, it's also destroying the thread because it's pinching and wiping it against the side of the hole.
What are my chances of bending the needle without breaking it? That's my first fear, as I don't have a replacement needle and am not sure if I can get one. I don't know how generic they are, if at all.
I also am not sure about which way to thread the needle. There's a flat on one side of the needle just above the hole- should the thread come in from that side, or the other? Does it matter?
There's an adjustment on the top of the machine, not labeled, and when I turn it a pin in a slot on the side of the head goes up and down, maybe 1/2 inch in total. Anybody know what that might be for? I can't see any effect from turning it.
There is no threading schematic on the machine, but if I follow the thread through the guides and the variable friction thing, it looks right.
The only 'selection' you get to do on this basic machine is for the length of each stitch. That works. I think my basic problem is that the needle doesn't come down totally centered through the foot, and that may be critical.
I'm really just looking for some guidance here. The only sewing I've done has been by hand, usually with a pig-sticker of a needle and string instead of thread.
http://img.photobucket.com/albums/v136/heinrich/borletti_zps7e2ae76b.jpg
