Help with a gear ID?
  • Help with a gear ID?
    I need to replace this gear out of my QCGB, for obvious reasons.
    However, gears and their proper nomenclatures are not my forte`. Apart from knowing it has (had?) 24 teeth, fits a 1" shaft and is nominally 1/2" wide, I don't know what to look for by way of pressure angle or... pitch diameter?
    I'm hoping I can find an off-the-shelf gear I can bore/key to fit in there, but I need to know what to order. I don't know if these photos will help or not, but I'll be happy to get additional measurements if necessary.
    In addition to the above, the teeth measure approximately 0.112" wide (more or less at the base) and going from the peaks of two adjoining teeth to the 'valley floor' is approximately .148".
    Doc.
    Looks to me like you have a 14DP 24 tooth 14 1/2 degree pressure angle gear there. Not so common a pitch any more, but searching for 14DP gears may get you something.
      I agree
        Well that's no help. Nothing in 14DP listed on McMaster, MSC or the recently-noted Amazon Supply. Heck, nothing even on eBay.
        And, naturally enough, I have some 36 Brown & Sharpe involute cutters, but not the one I apparently need. (If I have this right, 14DP, 14.5 degree PA, #5 cutter for 21-25 teeth. I have #1, #2, and numbers 6 to 8. Though no pressure angles listed.)
        Looks like I'll either have to order a cutter or make a single-pointer.
        Why doesn't anyone carry extensive replacement parts for seventy-year-old marques that have been defunct for 20 years.
        Doc.
          Here is a cutter I believe that you need on Ebay
          http://www.ebay.com/itm/NOS-Decovich...item51a1efb51f
          Harold
            Eh.. use a number 6 and make it. Might be a bit noisy, but should work. Won't be perfect. It's at the wrong end of the range, a #4 (26 -34) would be closer
            Or, buy the right one and make the gear.
            Seems like the P A should be listed on the cutter...
              Usual rule, AIUI, is that no marked PA means 14.5 degrees.
              Just like no marked form on Coventry die chasers means Whitworth form
              Tim
                Doc,
                Thought you might have scored as the 14 DP struck a chord. Drummond lathes use 14DP @ 14.5 PA as change wheels and a while ago I was involved in a project with these machines which involved some gears.
                So dug around and found the relevant tin, rack 5, bin 3, where I had placed it 12 years ago. Like tree rings to date trees I use spiders webs
                However no such luck unless you want 27, 21, 16 or 13.
                You could have had one of these FOC if it had been the right size.
                  Tim
                  Like the zoology rule I guess, "If there's nothing on the tree, it is the chameleon that you see."
                    try Stock Drive Parts:
                    https://sdp-si.com/
                      This wouldn't happen to be a Sheldon lathe would it? If so look at this gear. It might be worth sending an email to get him to measure the diameter. http://www.ebay.com/itm/Sheldon-Lath...item35d0743b30
                        Been their done that.You not going to find a store bought gear that pitch,I have looked . Lots of old lathes used 14 DP gears ,but you will have to make it . i have a whole set of cutters in 14 DP just because of that . If you cant find something . PM me and I will make you one .
                          Tim
                          Maybe.... these are all marked, I think every one I have is marked....
                            Jerry,
                            now look for one that isn't marked and tell us what angle it is ?
                              I don't have any not marked.... that I know about.
                              But I'd have to probably do some pretty tricky measurements to get a good number.... although 14.5 and 20 look like different numbers, they no doubt look pretty close when you go to measure a small gear tooth.... I'm not sure I have adequate measuring "stuff" to even try it. And don't even ask me to do that with a 48DP gear....
                              Interesting question though.... you mean it as a joke, but I suppose it is do-able.. You'd have to find the pitch diameter, and determine what the tangent line to the tooth is at that diameter (pitch line), and then compare that to a radius... getting the angle between.
                              I think I'll stick to reading the nice number off the cutter, thank you very much!
