Cross feed dial locking methods
  • Lew Hartswick
    Originally posted by dp View Post
    I bookmarked this thread some years ago
    http://www.practicalmachinist.com/vb...e-screw-150571
    WOW!!! I just spent a couple hours reading that. GREAT thread. Thanks for the reference.
    ...Lew...
  • dp
    I bookmarked this thread some years ago as being one of the better build threads at PM:
    The dial lock may be stock, dunno, but it's a nice looking dial.
  • Optics Curmudgeon
    Originally posted by martik View Post
    looks more like an operating room to me, why so clean?
  • martik
    Originally posted by browne92 View Post
    Does come under the category of machine porn, doesn't it?
    Here's some tool porn for ya:
    http://www.micro-machine-shop.com/Mi...to_Gallery.htm
  • Bob Fisher
    I am SOOO jealous! What a beautiful machine.it must be a real pleasure to use.Bob.
  • browne92
    That is just obscene... but gorgeous! Makes a cool desktop background. Do you have a photo link of the rest of your EE?
  • martik
  • daryl bane
    The Monarch EE uses a tapered disk that bears against a mating taper. It's a tad overbuilt, but very effective. Here's a pic of my homebuilt repop. Unfortunately what is not shown is the inside friction disk. It is a thick disk with a mating outside taper to fit the movable inside graduated ring. This disk has a key that engages with the machined slot(pictured), to keep it from from rotating. There is a hardened pin on one side to keep the disk centered and then when the thumbscrew( again not pictured) on the outside face of the outside graduated ring is tightened, it bears against the disk and locks into the taper on the movable inside graduated ring. I hope this is clear. Sounds complicated but quite simple.
  • gzig5
    I like the friction type. My EMCO FB mill used a radial leaf spring under the dial. Worked well but might be tough to implement so a properly sized o-ring and groove might be next best. An important thing to consider is if the dial is used as a thrust surface, like on my Atlas/Craftsman lathe in OEM configuration. In that case a carrier of some sort should be worked up to provide the thrust function and the dial can ride on the carrier.
  • Tony
    my colchester has something very similar to the Rivett as linked by Sun God but mine a "friction".
    if I'm not mistaken, there are a few more bits including a floating pin (piston),
    a spring, and set screw -- no thumbscrew, no postive locking. But the "drag" can be set quite
    high, and they haven't budged (worn, etc) since I set them.
    I'd we wary of an oring losing its feel quickly. I like the sound of damping grease though.
    ps: I meant to suggest something like a "split ring" (ala piston ring) perhaps?
  • Sun God
    I like this the best, as used by Rivett, between ease of machining, aesthetics, and ease of use. I have nothing but good experience with friction locked dials (such as grooving underneath the dial body and fitting a tight fitting o-ring) in use, but I do like the idea of being able to positively lock the dial without touching the dial itself.
  • EVguru
    My Harrison uses a grub screw, sping and brass pad bearing on the shaft.
    Look up 'damping grease' as a possible solution.
  • dian
    i made a dial 20 years ago and just put some thick grease between the dial and the "hub". its very smooth and still in use.
  • martik
    started a topic Cross feed dial locking methods
    I am extending my crossfeed shaft and making some new dials for my SB9, so I figured it would be a good time to reconsider the locking method.
    Other than the standard "thumb screw in the dial" that bears down radially to the screw shaft, I have noticed two other locking mechanisms:
    http://www.gadgetbuilder.com/DialLock.html
    http://www.practicalmachinist.com/vb...e-dsc01612.jpg
    I'd appreciate hearing others' experiences with these types of dial locks, ease of use, reliability etc.
    Thanks
