Due to all the engine talk lately I did want to bring something up in a separate post so not to intrude on Brians engine build O.P.
We are living in a time where new engine idea's are dime a dozen, there is allot of rubbish to sort through - engines with no particular benefits yet a ton of pitfalls, but there's one thing im sure of and that's that Variable Compression Ratio IC engines are not a fad, they will be made very simply and be so practical with the power and efficiency benefits that they will be hard to ignore,,,
Here is a little taste of some of the bennies, http://www.youtube.com/watch?v=DdM2VbbdtB4
I have to add - this is nothing new - VCR's have been around for several decades - people knew even back then all the potential benefits but with all the electronic controls we have now comes unbelievable benefits that could never be realized before - changing ratio's "at the drop of a hat" can reap rewards throughout the range - it can keep volumetric efficiencies high AND power production AND optimized fuel burning AND therefor fuel consumption AND also reduce NOx emissions all at the same time...
To show just how long this idea has been out SJ's post of the Armstrong engine looks like it has little eccentrics on the lower pivoting ends of the rocker links and im thinking that's exactly what they were used for - there's also a plethora of other examples old and new.
But the point to all of this is the opposed piston engine offers a very simplistic solution beyond the complexities of many of example - and that is simply to split the crank and change the timing of the two crank throws in comparison to each other - furthermore - if there are intake or exhaust ports involved or if the crank halves are individually linked to intake and exhaust valve timing accordingly - the sky is virtually the limit as you can automatically incorporate VVT into the mix without any additional moving components --- the results would be a normally aspirated engine that could pull a stump out of the ground @ 1,500 RPMS and come on like an indy car at 10,000 RPMs +
The problem with allot of these newer engine designs is they simply don't get it - reciprocating pistons do not "waste power" they give back what they take --- and due to bore and stroke can be tuned to suit a variety of things and are easily serviceable, but that being said - just like any other engine they are "locked in" to a predetermined CR, sure you can add things like turbo chargers and such but you cannot "spool up" in an instant - you can go supers chargers but have to pay the fiddler in HP robbing parasitic drag,
With the invent of direct injection gas - turbo chargers make allot more sense - WHY? it's due to not having to run 7 to 1 compression ratio so they can now keep the thermal efficiencies up higher than before, but in comparison to VCR they are still crude cumbersome slow response devices...
Imagine a direct injection gas engine that runs without any spark plugs - and adjusts it's compression ratio within milliseconds to suit whatever needs are thrown at it, all whilst keeping control of the burn rate with pulse controlled injection, the possibilities are endless...
this is where we should be putting all our effort right now - mark my words this is the next biggest breakthrough - the mechanical's are nothing to create - we are already using hydraulic degree changing devises on most cars camshafts right now that are equipped with VVT... piece of cake... just one single beefy one for the two cranks to be linked too... that's your only added extra mechanical complexity...
