Hello all.
I have come upon a conundrum, folks. I have a Craftsman/Atlas 6x18 lathe, and I decided to try to take the chuck off. I'm looking at trying to find a new chuck, and some other things, so I thought I might try to check what size threads are on the spindle.
So after reading a little about how to remove a chuck from a threaded spindle, I went at it. I engaged the back gear and pushed on the chuck using the chuck key, in the opposite direction of normal rotation... well, that didn't work! I huffed and puffed and strained and grunted, and nothin'.
So, I stepped it up a notch. I put a crescent wrench on one of the jaws. I tapped on it lightly with a hammer, sprayed the chuck with some WD40... well, nothing.
After that, I decided to just put as much pressure as I could on the wrench. Now, here's my problem: in doing that, I've chipped off about three teeth from both the back gear and spindle gear. It still works and I rarely use the back gear anyhoo, but uh...
Thing is, if the chuck hasn't come loose and yet it's stripping gears... what the heck do I do now? It's like a catch-22.
Looking for a little advice, fellas. I know stuck chucks come up pretty often, but... this one's a little different. Thanks, all.
