I need to cut some gear shaped "teeth" (but not gears) sections on a disk. About the only way I can do it with my equipment is to make a form tool, to shape and them mount it in an arbor, perpendicular to the axis of the mill (vertical) and cut the "teeth" that way.
If I leave the tool flat on top it will hammer the part like crazy but if I grind some top relief (it is actually on the side when cutting) so that it cuts better it will change the shape of the tool and the profile of the finished part will be wrong. Grinding the sides at an angle that will give the proper profile with "top" rake applied would be, for me, strictly trial and error IE: a lot of extra work to get it right if I can do it at all.
It's the same as grinding a threading tool, flat top OK, with relief no longer 60 Deg. Do I leave it flat on top or is there a better way.
Any solutions?????
Any solutions?????
