Not sure if I've asked about this before, but at one time I had been considering building my own belt sander and wanted to use a granite tile as the backer for the belt. Now I'm getting close to building it, and wondering if the tile will be able to withstand the slipping of the belt across it.
Seems to me it will be fine, and the way I intend to build it, the tile will be replaceable anyway.
Normally you buy the machine, which would have a cast iron platen (backer plate, slipper plate- ) I intend to build my machine using mdf laminated both sides with countertop laminate. There will be steel where appropriate (bearing seats, etc) but other than that the whole structure will be this laminated material. The granite tile will be placed behind the belt in the 'work zone'.
I could of course line it with graphite impregnated fabric, but instead I'm thinking to make up a 'lubricator' of this fabric and have that in light contact with the back of the belt.
I'm also thinking that because the belt I intend to use is 12 inches wide, a crowned roller would be less ideal than some other method. I could copy the method used in the larger thickness sanders, where the angle of the upper roller is varied to keep the belt tracked within certain limits. I do intend to look into this in depth before I commit to any design.
At this point I'm just wondering what you all might think about using a granite tile as the platen-
