Found a way to get back in here.
  • Found a way to get back in here.
    Been away for sometime due to this site was so small I couldnt read anything. Then utube vidios went
    south. Tried everything, come to find out Utube and Google are playin games again with flash player.
    When I googled "Utube out of sync" holy smokes, seems thats the biggest complaint. Most common reply
    is that Utube is testing on its viewer with this HTLM5 thing that doesnt work with older pcs. OK I got out
    of google chrome and went back to plain ole internet explorer that still had an earlier flash player version.
    Problem went away. Now the test is, I close int. explorer, open google chrome, come here and I cant read
    nothing. I'm no computer geek but I'm just sayin if anyone else is having problems I think that should
    correct things. I myself personally know Keith Fenner and called him he was un awhere that his vidios had
    a good 5 sec lag. And then recently TubalCain commented on why utube can't leave things alone.
    mark this as INfo
    sam
    Changing text size in your browser is a basic simple feature. There's no reason why it should stop you enjoying any website. If you use windows, simply holding down crtl and rolling your mousewheel should adjust it 'on the fly', otherwise use ctrl and the + and - keys.
    Monarch 10EE 1942
      Hmm.. don't know about u-tube messing with stuff, but I have an old desktop that does utube fine, and a newer powerful laptop that has an error on every single video on utube... starts, then stops, repeats, starts, stops, repeats, and gives an error. it is totally reliable, does that every single time.
      Both have up-to-date flash player, up-to-date firefox
      I do not seem to get the option to re-size the resolution on the video with the laptop, it is stuck at max res, no other options displayed, which is probably why it causes trouble.
        I'm the last one to tell anyone how to fix computer problems but I do think if you hold down the right mouse button then at same time use the scroll wheel on mouse it will change size.I use an ipad now so I can't verify it tho.
          Verified. Ctrl-Mousewheel.
            On my SeaMonkey browser, on the toolbar I go to View and on the drop-down where it says Zoom I increased that from 100% to 120%.
              Interesting, I even got a couple PMs to see an eye doctor, no it aint eyes. What was happening was (example take the
              letter "W" and measure with a mic. it would be .004. I couldnt make out anything, looked like dirt on a paper. But odd
              enough it was only this site? Oh well its fixed now thanks.
                You might also want to break up your posts with spaces and paragraphs to make it easier for the rest of us to read YOUR stuff...just saying.
                John
                  Works great, thanks.
                    I'm on IE-11 and keep Flash updated. Very few sites make use of HTML5 but the ones that do are fast. The only time I've had problems on YouGotTubed is when my wireless ISP connection is loaded up. Even then, it just a brief pause then picks up. Perhaps you don't have enough memory to allow more buffering.
